Hi I have a 2002 RHD Carrera convertible with Alarm  / Central locking Issues
Only recently bought the car thought they would be easy to fix  seller obviously knew a lot more than me
What works
If you pull the Door Handle inside or out Window Lowers and also goes back up on close
If you press button on key luggage lid opens
If you press and hold lock button on key you can close or vent windows
When you press key LED on dash blinks
Key will lock and open driver door have 2 keys both work don't work the same
What doesn't work
No Alarm  Siren  Noise
Doors do not lock or open remotely
Alarm LED not on
No flash of indicators
Dash switch appears not to work except if you lock drivers door with the key
Which has no effect on passenger door but if you press Dash button Or the Key Drivers door will then  unlock
Have manage to get some fault info from alarm unit memory
47- Control locking synchronization--------- permanent
54- Radio receiver faulty ----------------intermittent
33- Passenger compartment monitoring sensors --------------intermittent
12-Door lock module fault--------------permanent
61-Central locking limit position unlock, not reached ---------permanent
1- Doors secured and terminal 15 on intermittent
Any pointers please  Thanks  still a great car to drive !!!
What works
What doesn't work
Alarm LED not on
I'd start by looking at the central locking system/alarm module under the driver's seat.  If it looks like it has been wet, that is your culprit.  This is a common problem on cabs/Boxsters when the rain drains plug and flood the box.  As yours is a RHD, it may be under the passenger's seat.
Do you have the factory original radio or is it an after-market system?  The remote locking/unlocking may be a separate and common issue. I would focus on the manual locking and unlocking first.
Edited by wyovino
