Hello I was hoping I could upgrade my base Boxster cluster to a Boxster S with the white faced gauges and need to know if the mph difference would be an issue since mine goes to 150 and the S goes to 175. I found one from a 2002 model I am going to buy if everything is simple enough to swap. Thanks for any input.
Edited by RE2Master
Misspelled simple
The cluster would likely need a PST2 or PIWIS diagnostic tester to transfer settings to work correctly. Besides transferring the mileage and country setting you would also need to transfer the options (cruise control and/or OBC). The cluster would not make your car go faster though... :wink:
You should also check with your state laws about odometer reading and transferring - as there could be further legal requirements.
Nah don't want to go faster just liked the look of the white faces and will change out the orange glow to a brighter blue for night driving. I will look more into the swap for recoding the cluster. Upgrading the radio to a Bluetooth system so the factory one is up for grabs to anyone interested. Bose premium sound but no CD changer. It works I just need Bluetooth.
There is also the issue of CAN Bus technology, a 2002 cluster would use it where an earlier model year would not, making the swap problematic depending upon the year of the cluster and the car.
Is this a tool I can buy myself? I saw icarsoft POR II when I searched for the PIWIS tool you mentioned for diagnostics and code resets. I need the tool regardless because my CEL is on and my gas vent valve is dead, fuse was good,and spitting gas when I fill up. Original radio is going in place of a Bluetooth unit so the VIN code won't matter for that fact.
Edited by RE2Master
Misspelled the, awesome spellcheck on my smart?phone
The PIWIS system is the Porsche factory diagnostic system and is only available as a leased unit, first year's lease fee is around $20,000.  You will see a lot of clones advertised on the web, most are either a scam, or a very old version of the system.
