99 Bosxter Base...I need to replace the dome light assembly because of a  bad micro switch(windows don't fully close). So... I have a replacement but its a 2001 I believe. It has a nicer  fixed dome light not the rickety one in the 99. Of course it has a different size connecter. The other connecters for the micro switch and infra red are the same. Was thinking of just fabricating a new harness. There are only 3 pins. I assume 1 common ground and 1 switched and 1 for continuous. Couldn't find the schematics in the factory serve. manual. Any thoughts about this. Thanks .....Hate that rickety one....ugh
