Hello I was in the process of removing old latch to replace with one and notice the bottom cable wire is missing or detached from assembly . Then there is this silver cable wire that still attached which I do not know how it get removed. The wire that I didn’t see attached to the old assembly would this be the emergency cable wire? If so and if I can’t find the cable end that connects inside bottom of the new assembly would everything else work mechanically locking and opening ect...
