I have most of the wiring diagram understood.
However, I'm confused about how to interpret
BOX E188
Normally I would read that as ROW 188, Column E on an electrical diagram.  But for a 99 Boxster
there are only 170 Rows.
thanks,
Mike
I think there is a page missing from the MY1999 Boxster schematics. If you look at later models E188 is on the Motronic 7.2 diagram - which seems to be missing. It also would imply that the "S" got DME 7.2.
1 hour ago, Loren said:
Sheet 19 in the MY2000.
Yes grid E188 exists in MY2000, but contextually it doesn't make sense, it's the pin 86 on same relay Re/Bl, not the pin 30 Yellow -- So I don't think that is it.
Ironically there is an E188 connection as well, but it is the wrong wire to the same Relay (Re/Bl pin 86).
Additionally, the page 19 schematic is wrong -- as it shows K48 connecting a Re/Bl wire to Start Lock, which is actually K158.  (looks like the connections are transposed)
On the MY99, in context -- the signal doesn't have the a split connection on the pin 50, Yellow wire seen on 1999 to E188.
I'm wondering if that is also a schematics error on MY1999.
Mike
Edited by txhokie4life
