 Just replaced my PCM2.1 with an Alpine iLX-207 HU and the HUR NAV-TV210,  2008 997TT with the Bose Amp.
Now I have my seat-belt chime coming on at 76MPH and off at 71 MPH WTH!!!
Anyone have any thoughts I have a Durametric Pro and went into the instrument cluster  and turned all the chimes off.
Another interesting thing the car is equipped with the Sports Chrono it hasn't worked since i purchased the car in August 2018 not it does work.
It's not the speed limit warning in the MFD.
Are you sure it is your seat belt chime and not your speed chime. My dealer set my at 75 MPH and I turned that off after the first I hit it.
As I recall you can do that through the instrument cluster buttons - you shouldn't need Durametric.
Hi Loren,
It's seatbelt and whatever else(headlights?)  has the same sounds, speed goes off and flashes the warning on the multi function display.
Jay
Edited by jayi836
