DIY: Steering Knuckle / Wheel carrier removal for bearing replacement
Before I started, I called around and found a shop that has a press and many adapters, so they can press out wheel hub from wheel carrier, then press out the bearing, then press in new bearing and finally press in old wheel hub. Shop I found did it for me, charged me 20 bucks, 20 minutes.   Below shows you what you need to remove to get to the wheel carrier, so you can take it to shop and have bearing replaced.   Hope this helps out. You would want to do this if you notice noises in car
