DIY: Steering Knuckle Bearing Repacking
Before you install new bearing into the knuckle, it is recommended you repack the grease.  Why? The oem grease is about 200˚F. Repacking with high pressure and high temp (800˚F - CV-2), will ensure max protection. This will be part of my diy for replacing bearing, but making this separate in case folks do on their own too.
