Long story short. Did a bunch of work taking the cams out,replacing solenoid, IMS RMS,Clutch FW..... ran the car w/ lost timing....etc... Then had CEL for misfires, changed the MAF....misfires went over to the other bank. Then...I replaced my weak battery and haven' t thrown a CEL yet. I do however have pendings for misfires. Is it reasonable to say  I'm in the clear and solved my problem and DME just has to relearn the fuel trims? Engine sounds great.... revved to 5000RPM's to burp engine after a coolant change and this where it always threw a CEL when revving. But none so far.Thanks V
