Does anyone have a procedure & torque specs for replacing the mounts on an 09 base Cayenne? I've reviewed the parts diagrams and scoured the Internet and best I can tell you either have to drop the engine subframe or remove the engine brackets. Given the driver side bracket also has the oil filter housing I'd like to avoid if possible and there is very limited space there to begin with.  Any insight appreciated.
I have 101k miles and since my ownership began at 69k miles there has always been some vibration/rattle at idle and while observing the motor it moves when revving. I'd like to prevent any additional damage to the exhaust/flexshaft etc.
Mark
