Passenger window ,when you open passenger door the window does not roll down like the drivers side window when you open the door..
There is a switch bad but where is located, I love the car but it is new to me,  Any help will be appreciated.
Could be one of the microswitches, or another more common failure is the window regulator (the mechanism that raises and lowers the window).  Over time they develop slop and need replacement.  When you pull the door handle, listen closely to the door and see if it is making a noise as it tries to drop the window.  Another way is to open the door and see if you can push the window glass down a little bit.  If neither is the case it is probably one of the microswitches on the door handle.
