My 01 C4 coupe just underwent a number of maintenance items including IMS, RMS, clutch, AOS System, water pump, cooling system hoses...
On the way home from the work the ABS and PSM lights came on. The Durametric showed an ABS fault code of 5526 plus several accelerator pot errors (P1219, P1577, P1578). I can't find any information on the 5526 code. Can't find any list here. Can someone help?
Lang G
Indeed, incorrect pedal value from DME.  Clear the code in the DME.  Do a pedal adaptation...key on (no start) for 60 seconds, then key off for 10 seconds.  Do not touch or move the pedal while resetting the adaptation.  Drive and see if the code comes back.  A snip from the Essential Campanion.  Also, clean your MAF sensor.  It has been known to trigger both lights coming on.
Edited by DBJoe996
Thank you for the response. Very helpful. You said that that in fo is a snip from the Essential Companion. Page reference? I have that book but have not found the above info.
Lang
