I am wondering whether a bad fuel pressure regulator (in addition to a slightly bad fuel pump) can cause difficulty to start the engine when its "hot".
The are numerous possible causes for an engine to run rich, including fuel pressure, plugs, cats, MAF, O2 sensors, coils and wires, intake, and on and on and on. If you do not have a scanner, that should be your first investment. You can get a good one for $100 -$250. This will allow you to look at readings of all the major sensors of your car's engine. Knowing the sensor's readings will greatly help in determining what may be wrong. Most likely a lazy O2 sesor if the car is otherwise running properly.
