Hi all!  New to this community
I have a 2006 911 C4S Cab..Great car, but like everything else mechanical can have faults.
My left side fog light does not work, right side and rear fog lamp, headlamps, running lights all work fine. With the right side working, of coarse, everything is working proper, switch position and bulb is good. I checked and tested power at the plug. I am familiar with wire testing, due to a DMM volt meter can lead to false testing, because a DMM does not offer load to a circut . The ground,which is brown, load tests fine, the black with white trace is the power wire. The power wire shows a ground, because it not energized , which tells me it is either shorted to a weak ground, but more so it still attached to the relay. I cannot find if there is a relay for both left and right fog lights. Does anyone know? I see a yellow/white trace is right side power, so, there is a splice or two relays. Hard to fine this tech info. Thanks  for the ear!
