My '04 Cayenne S has popped PO155 twice now after ten minutes of driving on the return leg of a 33 mile drive in each case.  In between it popped some code related to the computer.  I don't recall the number as it looked like a random failure.  I suspected the rear battery but it load-tests fine, though it is original.
I currently have the connection apart on one O2 sensor on the left side so that I can test the heater circuit with my multimeter, but I'm confused.  It seems as though the computer may have shut current off to the wire upon detecting my intrusion, or maybe it's my meter.  Does anyone have a reference to troubleshooting the heated circuit on a before-the-cat O2 sensor?
Rod Croskery
