HI All
I have Porsche 996 TT modified to 1300HP
The car was running perfectly and drove more than 6000KM
never had any problems except last week when i braked hard the engine stalled
now the car wont start but it cranks
after serveral test i found that fault in camshaft sensor Bank 1
replaced it and still doesnt start
tested the DME to sensor voltage it 12V but when testing the DME out is 5V ?
how come at the end of wire is 12V and beggining of it is 5V ?
p0343 porsche fault code 112 - phase sensor 1 camshaft
any ideas please
Many thanks
Edited by Bahrain
If it's definitely the same wire, it is either open circuit or (less likely) the ground is not a good one.
Edited by Danyol
Expand
forgot to say that when connecting direct wires from ecu to camshaft sensors
a boost pressure sensor comes as a fault in diagnose and still not starting ?
Anything else happen leading up to this (flooding, rain ect)?
Check the big harness connectors on the right of the engine bay, re-seat them after making sure all of the pins look good. Check the ECU ground. I'm thinking the sensor is a symptom not the cause.
Expand
when i pull the fuel pump relay the car starts for 5 seconds only
nothing happened only when ever i use to brake the speedometer reaches 20km/h the engine stops but this time i braked so hard from 220km/h to 40 and the engine stops working till now
no rain or flood
  • 2 months later...
Hello
I am trying to verify the location of the camshaft position sensor A on 987.1 06 cayman s. Also where the ECU is so I can do physical inspection of wires. Any help will be greatly appreciated. I have changed spark plugs and fuel filter and AOS.
