Car started out fine but ended up on my manual tranny only able to use second, fourth and sixth gears. 1,3 and 5 were not engaging. Made it home and turned off the car. Restarted it and now all of the gears work. Any idea what is happening? Seems to stop working when the car is warmed up.
Check all shift cables/connectors under the center console and at the tranny. These are known parts to pop off causing shifting issues.
