I know this topic has been covered in the past, but I can't seem to find a definitive answer.
Loren or toolpants,
Is there switched power in the overhead/light console of my 03 996 cab, so I can direct wire my detector there? If so where is it? Upon operating the lights they all seem to work without the key in or unswitched. Or would you suggest I run it down the a pillar as others have done? It seems easier to run to the light console if there is switched power in there.
Neil
Thanks guys, I may have to go the Kirby route if I can't find switched power in the dome light. I did see these. I did not want to go the kirby route since I already have a nav wire in there, but I guess I could go down the passenger side.
Neil
Edited by neil.schneider
  • 3 years later...
