  • 4 years later...
  • 5 months later...
Remove L wheelwell cover. There's a few torx screws and 10mm plastic nuts. There is one bolt that holds the tank in, access it from the underside of the tank. It bolts upward into the sub fender(if you wanna call it that) work the tank out of the 2 rubber grommets on the right side of the tank. It should expose your washer motor. There are 2 motors if you have headlight washers. The outer motor (the easy one to access) is the headlight motor.
