Can some one give me a tip on how to identify the problem, I have a 2006 955 the engine was running perfectly I remove a fuse then the engine shutoff I re-install the fuse but the engine is dead on the LCD display shows four wheel drive system faulty, press brake pedal, warning brake proportioning, before that the car was running smood. I have 51k miles on it
Edited by Loren
Moved to correct forum
You're posting in the 958 section (2011-2018).. you might have better luck posting in the correct forum section.
What was the reason for the fuse being removed?
