I recently changed the spark plugs & found a little oil l on 2 plugs. Should I change the spark plug tubes & valve cover gaskets? If so where should I get them?
Sent from my SM-N960U using Tapatalk
There are orings on the plug tubes that can be replaced, but the cam cover has no gasket, it uses a special sealant compound.
If yours have the removable plastic tubes, these and the orings can be replaced without removing the cam cover.  If it has the metal tubes, the cam cover needs to come off to replace the seals, but that will require special cam holding tooling to prevent breaking the cams when the cover is removed.
