DIY: Panamera Oil Change
I did not bother to do a DIY for oil change, because there are some vids out there on how to perform this work. Below is a link to one of these videos, will walk you through the complete oil change. Items I used: - Oil: Castrol Edge full synthetic 5W40 - purchased 10 quarts, will use about 9 or so - Oil Filter: Mahle OX 254 D4 - replace this part every time - Drain plug: 900 219 020 31 - if you are gentle and do not screw up the hex hole in the plug, you can re use the plug. Be gent
  • 4 years later...
Hello!  Do you know the torque for the 13mm bolts on the brace?  Or is this a case of “make it tight”?
Aluminum bolts - so. hand tight then 90 degrees.
