I had my 996 passenger door painted to fix a scrape, they evidently pried up the window seal at the top of the door, and replaced it badly - leaving it "waffled." A new seal cost almost $300 and requires removing the door panel. Does anyone know how to re-seat the seal without going through all that?
Not really, that is why your body shop took a short cut.
Personally, if the body shop damaged it, I would insist they replace it. It's there fault. That being said, you'll have to remove the door panel to replace the upper window weather seal. Check out this video...
  • Like 2
