1999 2.5L with 25k miles
check engine light ON with P1128 & P1130
smoke test at throttle body no obvious leaks
oil leak at crankcase ventilation valve & near middle oil filler tube
currently working to replace AOS, oil filler tube, and other vacuum connections
Edited by tt9714
Once you have any air leaks fixed, check the MAF sensor.  That is a common fault for lean or rich mixture limits reached on both banks.
With the engine idling, the MAF output should read about 14kg/hour, and increase progressively as the revs are increased.
