2006 997.1 S
I'm installing an AIM Data logger and want to add some additional Oil Pressure Sensors for monitoring.
I've been told that the OE location is in the upper right corner of the 456 Bank and that there is a tapped and plugged location
on the lower right corner of the 123 bank. I figured that would work fir one and I was hoping to add an additional one somewhere that would give me
a reading closer to the sump. The goal is to differentiate between G Force effected readings and if I'm running the sump dry.
Any suggestions?
Mark
  • 6 months later...
Mark,
Put a oil pressure sensor in a oil filter sandwich plate - if you have a screw-in oil filter adapter.  In order to achieve good rpm and oil pressure relationships - the oil pressure readings need minimal lag.. putting the sensor near the filter will put it the closest to the pump.
Then find a 270 degree (3/4 circle) highway on-ramp, with continuous constant radius curvature..your Rpms at 3400 rpm or above, 15 min or highway driving immediately before hand, and hard cornering then look at your data.
I can’t wait to see  your response once you see the data..   email me if your interested in a better oil pan than currently available. I’ve tried them already. pkoepfgen@gmail.com
accusumps won’t get rid of air bubbles sucked into the pump btw.
-Pete
