Removing Stuck Ignition Coil Rubber Boot
Here is something that I think will help many here. One of the maintenance tasks I did was replacing coils and plugs.  Easy enough.   After replacing the parts, and while tightening the eTorx ignition coil bolts (aluminum), I was not careful and snapped bolt on cylinder 3.  BTW, its 3ft/lbs +90˚ (but with SMALL wrench, not 3/8) Since coils sit there pretty well, I left it as is until I got the bolt and had time to remove/replace (I do have some tips for removing the snapped part of the bol
