Several people have told me that the 996 Dual Sender Oil Pressure Switch/Sensor will directly replace the 987-1 Oil Pressure Switch. Can you please confirm this and provide the part number. I would guess it is 996-606-203-03 but, I would like to be sure.
Additionally, if I am running an AIM dash, should I run the pressure lead to the switch input on the ECU and get the pressure data from the CAN bus or, just leave the switch lead attached and run the pressure lead straight to an analog I/O on the AIM dash.
Thanks, Tim
