Hi there!
Quick question:
Is the code PO441 in relation to the fuel pump/ and or the replacement of it? I recently took my car in for a recall (fuel pump), 2006 Cayenne S. Since then, this code has come up. I have never had an issue before the recall part was replaced. I have regular service checks, etc. Just curious if there is any relation.
Thank you!
P0441 Fuel tank ventilation system above limit value/below limit value
Possible cause of fault:
- Tank vent faulty (remains stuck in an open or closed position)
- Tank vent installed the wrong way round
- Leak in scavenging lines between tank vent and positive crankcase ventilation (in the Turbo via a T-piece also on the intake side of the turbocharger)
- Scavenging lines between tank vent and positive crankcase ventilation trapped or blocked (in the Turbo via a T-piece also on the intake side of the turbocharger)
