Hello, I have the base CDR31 and the sound is very bad and I baught a set of 9 Bose speakers for only119$ free shipping.  I would like to replace all spekers and I need the wiring diagram especially to connect the terminal wire (+ and -) because I think the connectors are not the same.  When I removed the rear door trim for doorlock, I have seen an unconnected connector at tweeter level without any speaker.  Even in the center console there is no speaker at all.  On the top of that if I can fit an acive subwoofer, where I can find a line in ?
Thanks for your help.Set-9-Front-Rear-Door-Bose-Speaker-Woofer-Tweeter-Center-Cayenne-958-11-15-302482313205-2.thumb.JPG.f6cd6155b79151854f0864bf973b08f6.JPG
Thanks Loren, you are always there for everyone...   My cayenne is a 2011 base with cdr31.  Do you need the vin number ? Thanks.
