I got a roof leak in the passenger rear seat dripping down from the grab handle that is dripping onto the seat.  I just recently started parking the car in my driveway as our garage is filled for the time being.  The car is parked on a good incline so it would drain from the rear.  I did check the front drainage points and they are clear but I dont know where the rear drainage points are.  I would like like to check that before I take off the roof rack and re-seal it.
thx
  • 5 months later...
The grab handle area got wet for me too. Once roof rail removed, I found the gasket above wet area was giving up.  Replaced and it's good now.
Thank you, where did you get the gasket, I could not locate one
I cut plumbing 20mil pipe wrap tape to size and taped on the cleaned roof. Then dab clear caulk where bolt will enter roof.
