Hey guys, my new to me 2006 boxster S is having an issue
my homelink LED does not light up under any circumstances
I've followed the book procedures and the homelink.com online procedures
I never get any blinking lights
I did check and my heated seats do work and the led lights up as well
I bought the car used and have not done a new owner reset yet either, should I?
A couple of updates
1.  I checked all fuses - I had one that was over voltage 15A instead of 7.5A, so I swapped in a lower amp fuse but it was for the PCM so I don't think it's related
2.  I went ahead and did a factory reset on the PCM 2.1
Still no lights on the homelink panel - everything else I've tested thus far is just fine except the frunk light - it's out but bulb is good - going to have to open it up and try the wd-40 fix later
ANY ideas on this issue?  I'm assuming since I can't get any lights from the homelink, that's it's not worth calling homelink over
Thanks in advance!
So I mistook the rear window heater ( is that the the one in the convertible or the one with the top down) for a seat heater
turns out I don't have heated seats but I did the PCM reset anyway so that addresses that possibility of a fix
I also popped the covers off the buttons and all seems well underneath and with the button actuating the switch
anyone with other thoughts, I'd love to hear them, thanks
I found Loren's reply to someone else with a similar issue.
I'm going to try her suggestion next.
Start with fuse F2 (80A) (on the current distributor).
