Hello
i have had malfunction with ABS and 4 wheel drive have changed ABS pump.
all 4 wheel senors are tested and ok.
now the 4 wheel drive and and ABS works correct but the ABS indication lamp is still on.
all fault codes removed.
Also notice ice a slight drop in the break pedal when Iput pressure,  but that’s maybe normal ?
any advice ?
