1999 Carrera Tiptronic oil pan leak and fix
1999 Carrera Tiptronic oil pan leak and fix About six months ago I noticed the transmission pan was wet with ATF. Wrongly assuming the gasket was leaking, I changed the gasket and filler round seal and while I had the sump off changed the filter too. Torqued everything to spec and filled her up. Everything running smoothly. Three months later the transmission started to slip. Had a look underneath and the pan was wet again. Cleaned it up so it was totally dry. Took the
Edited by Ice Baby
forgot to include photo
