Have you guys experienced any "clunking" type of noise around the engine area when you step on the gas pedal? Somtimes when stepping on the gas pedal from a stop, the car will not respond immediately and the car will jerk a little and create a "clunking" noise. It feels like something was dropped underneath the car.
Dear Loren,
Thanks for your suggestion. I have taken the car to the dealer and the mechanic told me that the rear sway bar are tight. Also, the U or CV joints and the engine and transmission mounts are ok. What esle could it be that cause of this noise?
A while back someone reported a loose panel inside the trunk under the carpeting. I think they said it was obvious once they looked under the carpet. Sorry for the lack of details but it's easy to check.
