I noticed that my CTT HID light on passenger side, does not auto level when i start the car. Noticed because I started seeing the light try to reset (blink momentarily), while driving. Then replaced bulbs, and blinking still persisted.
Then noticed when I start the car, that same HID bulb on passenger side does not do the auto level when car started and lights turned on. I am certain the blinking connected to the auto level not working. Trying to figure out the cause.
If you have advice, appreciate the help. Thank you.
The link to the passenger side sensor (on the wishbone) may have broken off. That's where I'd start my investigation.
Edited by Oggie
Check the connection/plug/wire harness going into that headlight. Many times I've seen the level control not function because it came unplugged going over a bump or during a panic stop. The connection / mounting and retaining mechanism on those headlights is the achilles heel of the whole setup.
