what should i do ,i am only trying to remove the driver sit just for cleaning,and i am afraid to remove it ,because there is a connector under the sit ,should i be disconnect the batteries first?before i remove anything at all ?
I assume you're talking about the connector under the drivers seat. As long as you dont turn on the ignition while the connector is unplugged, you wont cause any airbag faults.
