Hi folks,
Can anyone tell me what this panel is (toward lower left of photo with two diagonally set bolts--ignore green/yellow arrows)?
It seems to be the source of a small coolant leak.
Does it have a gasket, and if so would a coolant drain be required to change it?
Don
It's just a lid covering a coolant opening. On a MkII, the lid includes a built-in gasket. I think it has a separate gasket on a MkI.
Oh, if you remove it, most coolant will come out. Similar to opening the coolant drain plug at the bottom of the engine.
