I got a 97 boxster with the stock 17" wheel ,i am looking to get the H&R wheel spacer ,my question is what will be the right sizes for it and do i have to go with the longer bolt's ?appericiate if someone can provide me the info .thank's
and you will need longer bolts. Also usually when you get the bolts you will have to move the collars from the old bolts to the new ones. H&R makes appropriate wheel spacers and bolts.
I am in a similar scenario that you. Have you opted for the 7/17 mm spacers and if so can you possibly post a few photos.
Thank you.
