I took off my air box (attaches the air intake with the air filters inside) to check belts. Now I need to get it back in. However, try as I might, I can’t get the rubber neck to completely go on the bottom of the air intake on the engine. I’ve done this before on a 996 without issues but on my 997.2 4S there seems to be very little space to be able to negotiate the bottom of the rubber hose over the bottom lip of the air intake. (See attachment). Either I’ve got fat fingers or there’s a method to it that I’m missing.
Sent from my iPhone using Tapatalk
I've always found it easier to put the bottom on first.
Thanks. I was aiming to get the bottom on first also, but there’s not much room on the 997.2 to pull it back far enough and down to get it on. At least for my fingers.
For others losing knuckle skin on this:
I solved this by moving the adjustable clamp completely back. Then I used my fingers from the top to poke inside the rubber tube bending the top rubber down so I could push the lower rubber lip down from inside under the intake. Once that’s on, the rest falls in place. Of course this bending puts strain on the rubber but replacing that (if ever) is much cheaper than my time and skin.
Edited by dammad
