Just installed lighted sills myself following Kevin M.'s directions under DIY section. Piece of cake...they look cool, too. Much easier than the OEM install directions. Hint: the power to the foot well light under the steering wheel stays hot for only 10 mins. then cuts off so you don't need to disconnect the battery to tap into the red power wire. You can verify there is no power when the red light at the rear of the front door edge is off.
