Hi all, new member, but regular visitor to the forum(s)
I have a 2002 986 3.2S that appears to have a fault with the front headlight indicator.  Will work for a while, then put the turn indicator on and flashes quickly to indicate bulb gone.  If I get out and push the headlight down, it will work for a while, then do it again.  I have taken the headlight out, changed the bulb, and put it back in, but it makes no difference.
Any suggestions would be appreciated!
Kind Regards,
:welcomeani:
It sounds like either the headlight socket (in the car body) has a loose wire connection or the socket may be damaged.
Remove the headlight and use a flashlight to investigate.
