I was checking / fixing fuses, pulling them and putting new that kind of stuff and now my windows do not open and the front light are always on! The fuses are ok but I am wondering if by playing around maybe i messed up a relay or something! I tried to fix the fuses to what they should be, in the past the car ( used ) had fuses too big for what the chart called for, so for example i replaced a 30 for a 10 if a 10 was the one needed etc.
Edited by BENC911
Expand
Have you tried disconnecting your battery cable(s), touch them together, and reconnect the cables to the battery?
These cars do strange electrical things when the battery is weak.
How old is your battery?
If it is 4 years or older it should be replaced.
Well things are better, now I have pasm issues ONLY
What is the fuse or fuses? I remember that I could do inside the car pasm off, but now the button are not lighting up, neither the one that looks like a shock absorber nor the one that says sport. That one gives an error which I guess has power?
it was weird 3-4 fuses in one of the slots had no power, I did a split from one with power and I was fine. Not sure why it did not have power, maybe I have a relay issue that also feeds the pasm? Not sure but at least all but the PASM is working.
Edited by BENC911
