I noticed my hood emblem was loose. Upon investigation I found out that one of the plastic pins was broken. The part where the flat part of the pin is bonded to the emblem has come detached. I have removed the emblem but the pin and the nut holding it in place remain. Any suggestions on how to remove the nut? - I need to hold the flat part of the pin from rotating while I unscrew the nut. Problem is I don not want to bend the flat part because once I remove it, I will simple super glue it back on to the emblem and reattach the emblem with the nuts. Can this be done or should I just order a new emblem and spare myself the hassle?
I'm not sure if super-glueing is likely to be a permanent solution. Usually the emblem gets damaged when people press on it to close the bonnet.
I'd probably buy a new one, over here they are about 45 Euros, so I guess that'll be about 50 bucks.
Cheers,
Uwe
Hmm - you're right about pressing near the emblem to close the bonnet. Is there another proper way to shut the bonnet?
Edited by my996
The mounting pins are metal. It helps to have 2 people. One grabs what little sticks out with pliers that have sharp teeth, and the other turns the 8 mm nut with a socket. Then I solder the pin back on.
I have done this for local owners who press on the crest to close the trunk.
