Found the PSE vacuum line loose behind left exhaust pipe.
Hooks to what looks like a solenoid on left side above mufflers but can't figure out where the other end connects.
Any wisdom would be sincerely appreciated!
Thanks very much Loren,
The line that is loose is the one where the arrow on the lower left points up and goes up to A.
Where does that line come from? That is the one that is disconnected.
Found the loose hose end and reconnected.
BTW - Need to be a contortionist to reattach the steel armoured hose to the other line.
