My key fob won't work randomly. It will sometimes unlock and sometimes won't. I had to get AAA to open it the other day because the key fob didn't do anything and my key hole broken. In addition now the rear windows won't roll up. Anyone have these issues?
This is a common phenomenon when there is a problem the central locking/security controller under the driver's seat, often because it got wet.  I'd start there.
Do you have a spare keyfob or is the malfunctioning key the only set you have for your 996? Your answer to that question will determine the next step.
Hello if you want I can learn used key fob to your car again ,You haven't buy another new if is your key fob damaged totaly .
