I had a blocked right hand head light washer jet, so I replaced it. But now the water from the washer bottle keeps draining out through the new nozzle. Is there supposed to be some check valve in the jet carrier part that bolts behind the front bumper/spoiler?
If I re fit the old blocked jet nozzle jet the leak stops and also they're is no leak from the left hand washer jet nozzle which is working.
A replacement jet carrier is £52 ($75) so I wanted to be sure this is the problem before I order.
Thanx for any advice
Ok there is a pressure valve in the jet carrier. That's what stops the fluid from draining out. I tried to dismantle the old unit but was unable to get it apart.....so I purchased a new OPC item and all is now well
Sent from my SM-G935F using Tapatalk
