Panamera turbo rear differential fluid change
Follow each picture in order from start to end.   Read entire set before you start.  This gives you a good idea of what to expect, without any surprises (oh, I dont have this tool, etc). This DIY uses Mobil Delvac 1 full synthetic gear oil 75-W90, which I was able to reference to the replacement fluid Porsche recommends - Shell TF0951. Replacement schedule is every 120,000 miles or 12 years.  I would definitely not wait that long to do this.  After 60,000 miles the fluid is not ev
