Can anyone please tell me if in an emergency I can temporarily install the 19"x8" tire from the front to the rear of the car replacing the 19"x11".
Thanks.
If you are talking factory wheels - then probably not.
The front and rear wheel offsets are different and I doubt the front wheel clearing the brake rotor or suspension when placed on the rear.
Although not ideal situation, the front wheel should be suitable as a temporary spare.  Front offset is lower than rear, and rear brake is smaller than front so you should be OK.
Back in my 993 days, that's exactly how you do it. If the rear goes flat, you move the front tire to the rear, and put the space-saver-spare-donut on the front. Keep speed below 55 mph. Seems reasonible this would remain true on the 997.
