Panamera turbo Spark Plug Replacement
Here is a DIY for spark plug replacement.  If your coils need changing, use this DIY as well. Hope it helps others.   This is a simple maintenance item.  Dealer will charge upwards of 500 dollars.  you can do this spending about $60 on plugs, and few hours of time.  Think how much beer money you will have left over.     If you don't normally work on cars, expect to take about half day.  Still real easy to do, just take your time, don't rush. If you do other DIY
