Does anyone have the specs for rotor thickness for the GTS MY2013?
Is it the same as the turbo ?
Im looking for the new /min spec
thanks in advance.
34 mm front -- minimum front 33.6 mm
28 mm rear -- minimum rear 27.6 mm
for steel brakes (all are the same according to the service manual).
Thanks I have to re measure because I got a reading of 35 which does not make sense.
Thanks again!
